Can you tell me if there is a method to signal when the PWM output toggles from low to high or high to low?
FC9
PIC24fj64GB002
PWM notice
alanwms
- Has thanked: 26 times
- Been thanked: 8 times
- Has thanked: 292 times
- Been thanked: 458 times
Re: PWM notice
Looking at p165 of that chip's family datasheet, it seems an interrupt is available for the PWM module. You will probably need to create a custom interrupt for dealing with this, which means understanding the datasheet requirements and coding the appropriate C-code.
