dfrobot has a nice ESP32 Board. It's easy to program with FC9.
https://wiki.dfrobot.com/FireBeetle_Boa ... KU_DFR0654
On board there is a GDI connector for display present.
Are this GDI already supported by Flowcode?
Can I use some of this Display?
1. 1.54inch 240x240 IPS TFT LCD Display with MicroSD Card Breakout https://www.dfrobot.com/product-2072.html
2. 2.0inch 0x240 IPS TFT LCD Display with MicroSD Card Breakout https://www.dfrobot.com/product-2071.html
3. 2.8inch 320x240 IPS TFT LCD Touchscreen with MicroSD https://www.dfrobot.com/product-2106.html
4. 3.5inch 480x320 TFT LCD Capacitive Touchscreen https://www.dfrobot.com/product-2107.html
FireBeetle ESP32-E GDI (General Display Interface)
- Has thanked: 246 times
- Been thanked: 258 times
- Has thanked: 795 times
- Been thanked: 858 times
Re: FireBeetle ESP32-E GDI (General Display Interface)
Hi.
It looks like the 3.5in uses a ILI9488 driver and the other gLCD's uses ST7789V
Flowcode does support those chips, so hopefully, they will work.
Hi Martin
Thanks a lot Martin. That sounds really good. So I can use any of these displays. I'll order one and post the program later.
What I like about these displays is the connection with a very small 18-pin flat cable or with the normal "dupont" cable.
