PWM component alternate port problem with PIC18F2520
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
Hello Matrix,
I belive I found a Bug in the PWM component with PIC18F2520.
If you assign PWM Channel-2 to the alternate port (Port B3), the hardware is not giving you the PWM signal
Channel-2 Port C1 is OK
Channel-1 Port C2 is OK
Attached the FC file:
PWM Check.fcfx
(8.07 KiB) Downloaded 263 times
Foto too:
PWM Problem.jpg (120.66 KiB) Viewed 3240 times
It would be great if some one could fix this issue.
Thanks in advance
Dirk
Happy FC9, FC-8 and FC-6 professional user ;)
Has thanked: 647 times
Been thanked: 856 times
Re: PWM component alternate port problem with PIC18F2520
Hi Dirk,
If you go into the Build -> Project Options then look at the Configure section there is a setting marked CCP2 Mux, You need to change this from RC1 to RB3.
Hopefully this will get things working for you.
dvcam99
Post by dvcam99 »
many thanks!! You saved my day!!
This is the solution.
BR
Dirk
