Hello I use Atmega128 processor and AT25F4096 memory.
Writing to memory works correctly but reading always returns 1.
Flash W25 reading doesn't work
Osta
- Has thanked: 1 time
- Been thanked: 5 times
- W25.fcfx
- 3
- (16.37 KiB) Downloaded 662 times
- (view online)
- 2
- W25.jpg (45.27 KiB) Viewed 8997 times
- 1
- Prog.jpg (28.79 KiB) Viewed 8997 times
Re: Flash W25 reading doesn't work
Found my mistake, but the question remains...
- W25.fcfx
- (17.71 KiB) Downloaded 621 times
- (view online)
- 2.jpg (43.63 KiB) Viewed 8979 times
- 1.jpg (36.81 KiB) Viewed 8979 times
- Has thanked: 647 times
- Been thanked: 856 times
You might need to erase the block first before you try and program the location. Though 255 would potentially indicate an unprogrammed location.
Erasing does nothing!
Cleaning up didn't do anything either.
Made a write / read loop and the loop stops.
the program hangs. Recording doesn't work.
Only reading works.
Only reading works.
- MEM.fcfx
- (24.05 KiB) Downloaded 598 times
- (view online)
- 1
- Ind.jpg (91.51 KiB) Viewed 8923 times
When connected according to the datasheet, there is not even a read.
And if the pins MOSI and MISO swap places, the chip returns 255. This is the default value.
In the program you can see that I set the value to 0 and the return value to 255. So the reading is done. But the sector is not unlocked and therefore not written.
Respectfully Osta
Respectfully Osta
