BMP280 when reading pressure, it's reading Temp and pressure
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Post by Xbiotec »
I checked with logic analyser and it show that BMP280 component is reading both Pressure and Temperature when request is to read pressure only. But only pressure data are store.
Pressure read.jpg (34.58 KiB) Viewed 8536 times
Pressure R.jpg (17.21 KiB) Viewed 8536 times
while for the temperature it is good, only the temperature is read.
Temperature read.jpg (38.63 KiB) Viewed 8536 times
Can be good to have a new macro able to read both temperature and pressure in same time :D
Seb
Has thanked: 795 times
Been thanked: 858 times
Re: BMP280 when reading pressure, it's reading Temp and pressure
Hi Seb.
Thanks for the good spot.
I have updated the BMP280 to just read pressure and attached the component for you to try.
The comment should be placed in C:\ProgramData\MatrixTSL\FlowcodeV9\Components
If you are happy with the component, I will arrange for it to be pushed onto the update system.
Grove_Barometer_Sensor_BMP280.fcpx
(7.83 KiB) Downloaded 682 times
Xbiotec
Post by Xbiotec »
It work's but why there is 5 Val now?
5 Val.jpg (37.72 KiB) Viewed 8528 times
Seb
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
medelec35 wrote: ↑
Thu Feb 17, 2022 11:18 am
Is that a valid option? I seem to recall the temperature is required for compensation calculations but may-be I’m mixing up devices…
Xbiotec
Post by Xbiotec »
Need Pressure, altitude pressure and temperature of course.
As you can see on the picture I sent to you there is 5 Val form Val0 to Val5, why ?
5 Val.jpg (44.89 KiB) Viewed 8519 times
Seb
Xbiotec
Post by Xbiotec »
I understand your meaning Now !
I'm checking !
Seb
Xbiotec
Post by Xbiotec »
You are right kersing, to calculate pressure, need Temperature too.
So finally need both pressure and temperature to calculate pressure !
Sorry Medelec
Capture d’écran 2022-02-17 152344.jpg (63.58 KiB) Viewed 8518 times
Seb
kersing wrote: ↑
Thu Feb 17, 2022 1:23 pm
Thanks Jac.
Thinking about it pressure is related to temperature, so it makes sense to keep it in.
lucibel wrote: ↑
Thu Feb 17, 2022 2:10 pm
5
That is odd.
I did not change it from how is was.
I'm looking into it.
Xbiotec
Post by Xbiotec »
this is mine
Capture d’écran 2022-02-17 173229.jpg (5.01 KiB) Viewed 8511 times
Capture d’écran 2022-02-17 172545.jpg (15 KiB) Viewed 8511 times
Seb
Xbiotec
Post by Xbiotec »
This what you asked me to try end of January then you updated the library with version 9
Re: ESP32 TTGO+ BMP280 temp sensor BUIL FAILED
Post by medelec35 » Mon Jan 31, 2022 10:56 pm
Hi Seb,
Thank you for the spot.
Can you give the attached component a try, please?
In file explorer address bar, paste this:
CODE: SELECT ALL
Save the attached file into the above hidden folder.
Just select ok to replace the current file.
If you got Flowcode running when the file was placed in the components directory, you must select the reload icon before compiling again.
If it works for you the component will be added to the updates.
(7.59 KiB) Downloaded 16 times
Seb
