Hello Team Matrix
here I am again.
I wanted to flash all possible IN/OUT ports for 1 sec.
GPIO:0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,21,22,23,25,26,27,32,33
all on all off etc.
The simulation works.
3 guesses what doesn't work?
Any ideas?
None of them flashes every second.
6 - 11 fidget somehow
partly on partly off
partly undefined.
If I deactivate 6-11, the rest flashes correctly.
The board comes from AZ-Delivery.
Greeting SpeedPic32
I/O Problem ESP32-Dev Kitc V4
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
LeighM
- Has thanked: 110 times
- Been thanked: 302 times
Re: I/O Problem ESP32-Dev Kitc V4
Please read ESP32 documentation
https://docs.espressif.com/projects/esp ... /gpio.html
SPI0/1: GPIO6-11 and GPIO16-17 are usually connected to the SPI flash and PSRAM integrated on the module and therefore should not be used for other purposes.
SpeedPIC32
unity-control
- Has thanked: 23 times
- Been thanked: 11 times
Just beware some ports have got pullup/pulldown resistors and as Leigh mentioned are special ones, so avoid using those.
An excellent reference I found whilst having similar issues here, have a check and take note of each and every I/O pin:
https://randomnerdtutorials.com/esp32-p ... nce-gpios/
HTH
HTH
