Uart!
jgu1
Has thanked: 839 times
Been thanked: 205 times
Uart!
Post by jgu1 »
Hi!
I was making a program with tx and rx, Uart.
In this att. program when I use this in FC9 the display is filling the display up with strange sign, run all the time. I try yo make the same examble in FC8 it work and waiting, when data is comming in it´s ok?
What am I doing wrong please?
Br Jorgen
Same FC8.fcfx
(10.34 KiB) Downloaded 153 times
RS232_ExampleRX2 Fc9.fcfx
(13.05 KiB) Downloaded 165 times
Has thanked: 724 times
Been thanked: 783 times
Re: Uart!
Hi Jorgen.
I have not looked into the reason, but try
If: in > 0
jgu1
Re: Uart!
Post by jgu1 »
Thank you Martin. I test your suggest later today. But the strange it work as it should in FC8.
You hear :D
Br Jorgen
Has thanked: 163 times
Been thanked: 960 times
Re: Uart!
Post by mnfisher »
Hi Jorgen, another suggestion is to print in as a number instead of using PrintAscii (note that only characters >= 32 (ascii for space) will show on the display.
An interrupt to receive input would have less chances of 'missing' input.
Re: Uart!
Hi Jorgen.
I have looked into this now.
The reason is that within RS232 properties there is an option to select Return of 8bits or 16bits.
If 16bits then the valid numbers are 0 to 255, therefore 256 is returned for no data.
With the variable
 in
set as a byte type, it can't go up to 256, therefore it's rolled over to 0
If you change Return to 8 bits, then 255 will be returned for no data.
Therefore you can revert back to
If: in < 255
jgu1
Re: Uart!
Post by jgu1 »
Hi Martin!
Well spottet :D I change to 8 bit and Print number, now nothing happend before I receive data and now it work perfect.
why had I not seen it you are brilliant :D Concerning the interrupt, I know this will be better. This was my first test in a project for IR remote control.
Yes, you will say, " IR remote control and RS232" make no sense :lol: Do you know these: https://www.ebay.com/itm/303292076882?h ... SwR91dhX9T
Work perfect an very easy to use the data which coming out and can be used.
Thank´s again again again Martin & Martin
Br Jorgen
Re: Uart!
That's brillant!
I'm glad you are all sorted.
jgu1 wrote:
Mon Feb 28, 2022 3:58 pm
No, not at all.
I have used UART in transceivers and wireless remotes, which allows pairing.
