ESP32 real Watchdog and brownout disabling
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
Please add a working feature for the ESP32 to disable the Brown-out and Watchdog detection.
Thank you.
Has thanked: 629 times
Been thanked: 836 times
Re: ESP32 real Watchdog and brownout disabling
I've been through and hopefully added working code for the auto watchdog feature to function correctly.
For the watchdog it looks like you can play with the settings via the sdkconfig settings file.
The line should look like this.
CONFIG_ESP32_BROWNOUT_DET=y
Hmm sorry I hit a wall with the watchdog fix I did. It should have worked but was causing compile errors and I couldn't seem to resolve them.
Anyway for now the answer to the watchdog problem is documented here.
viewtopic.php?p=3568#p3568
I'll keep trying for a none c code based fix.
