ATTINY44 the interrupt doesn't work TMR1
Osta
Has thanked: 1 time
Been thanked: 5 times
Post by Osta »
TMR1 interrupt does not work in the hardware
BG.fcfx
bg
(15.47 KiB) Downloaded 411 times
Has thanked: 607 times
Been thanked: 803 times
Re: ATTINY44 the interrupt doesn't work TMR1
I've had a look through the datasheet and compared with the generated code and I think I might have found something. The interrupt vector was declared as TIMER1_OVF but it looks like this might not be correct on this device, annoying it doesn't generate a compilation error to make it more obvious. I've changed it to TIM1_OVF and hopefully that will solve the problem for you.
The latest fixes are now available via the update system. Let us know how you get on.
Osta
Has thanked: 1 time
Post by Osta »
downloaded the update but it's not working. Now it doesn't work in the emulator either.
ModUpr.fcfx
(15.06 KiB) Downloaded 414 times
Osta
Has thanked: 1 time
Post by Osta »
Checked in the iron all works, but in the emulator stopped working.
Regards Osta.
ModUpr.fcfx
(15.09 KiB) Downloaded 425 times
Great glad the hardware is working as expected. What emulator are you using?
Osta
Has thanked: 1 time
Post by Osta »
BenR wrote:
Mon Mar 14, 2022 12:10 pm
Hi!
Sorry I didn't reply right away, I was on vacation.
I use PROTEUS.
Respectfully Osta.
