Thermistor!
jgu1
Has thanked: 795 times
Been thanked: 197 times
Thermistor!
Post by jgu1 »
Hi!
In My curiosity I would try an experiment and test the thermistor component. I think it was you who made it Martin. When I simulate it work nice
but in real world nothing happend. If I set the Wiring to Pullup the display only show 125.00 If I flip to pull down it show -25 No matter what I do to the analog input, no change.
I have a divider with a 10k resistor in serie with the thermistor and take the signal out in the "middle". just like a potentiometer. Suppose that is ok?
I made a test macro to check the analog input, and it work.
What am I do wrong, please.
Br Jorgen.
Thermistor.fcfx
(12.76 KiB) Downloaded 202 times
Has thanked: 696 times
Been thanked: 767 times
Re: Thermistor!
Hi.
No that's not one of my components.
What I believe is going on with the thermistor component is the Vref option is default to AREF instead of AVCC.
Can you try connecting the AREF on the Arduino to +supply.
jgu1
Re: Thermistor!
Post by jgu1 »
Thank´s Martin. Though it was you, sorry :D
You mean in Properties, no it is not possible to change? Edit, ohh you mean on the Arduino, I test.
Connect the Aref to the 5V on the Arduino, now it fluactivating up and down.?
Re: Thermistor!
jgu1 wrote:
Wed Mar 16, 2022 8:30 pm
Not a problem. :)
Not at the moment.
I will be changing the component so Vref options will be able to be changed.
You could have a poor connection, especially if using Dupont wires?
An easy way to test is to make the ADC input exactly 1/2 the supply voltage with two resistors of the same value or a pot.
You should then see 25C on the display.
jgu1
Re: Thermistor!
Post by jgu1 »
Again you are rigth Martin Thank´s, bad wire work now and stable and react fast. Only need calibration.
I dare to ask again, why should the 5V be connected to Aref and who could know this, can´see it anywhere? :lol: Now the device is an Arduino, what if I change to some kind Pic? ;)
Thank´s in advance
Jorgen
Re: Thermistor!
jgu1 wrote:
Thu Mar 17, 2022 4:27 pm
That's great, I'm glad it's stable now.
That is a very reasonable question to ask.
The issue is ADC for AVR default is to use the external reference (AREF) for Vref options.
Therefore either need to connect external reference to a voltage source
Or
Change Vref option to AVCC = VDD.
You can change the Vref option for the standard ADC component, as that is an exposed property.
Unfortunately, you can't change the Vref option on components like thermistor that uses ADC component, but the Vref option has not been exposed to properties.
I can correct that this morning
So, when Ben pushes the update on the system, the updated thermistor component will have the Vref option within properties.
All you will need to do is change Vref option from AREF to AVCC, then the wire from AREF can be removed.
The PIC is not affected as VREF option defaults to VDD
jgu1
Re: Thermistor!
Post by jgu1 »
Thank you very much for your explanation Martin. and thanks for the update concerning Vref. I will test when Ben update.
I'm actually amazed at how accurate NTC is, so far, just now it working need to play a bit more with this. I know that NTC not is linear. I have to test "on the way up" and need adjustment in config.
Jorgen.
