BME688 ESP32 ESP8266 Rasberry PI AVR
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
Hello Team
I have found something very interesting and would like to ask you to implement it in FC9.
With kind regards
SpeedPic32
BME688
Environmental sensing with Artificial Intelligence
The BME688 is the first gas sensor with Artificial Intelligence (AI) and integrated high-linearity and high-accuracy pressure, humidity and temperature sensors. It is housed in a robust yet compact 3.0 x 3.0 x 0.9 mm³ package and especially developed for mobile & connected applications where size and low power consumption are critical requirements. The gas sensor can detect Volatile Organic Compounds (VOCs), volatile sulfur compounds (VSCs) and other gases such as carbon monoxide and hydrogen in the part per billion (ppb) range.
Additionally to all features of the BME680, the BME688 has a gas scanner function. In standard configuration, the presence of VSCs is being detected as indicator for e.g. bacteria growth. And the gas scanner can be customized with respect to sensitivity, selectivity, data rate and power consumption as well. The BME AI-Studio tool enables customers to train the BME688 gas scanner on their specific application, like in home appliances, IoT products or Smart Home.
https://github.com/BoschSensortec/Bosch-BSEC2-Library
https://shop.watterott.com/BME688-Break ... uetesensor 17€
Has thanked: 246 times
Been thanked: 258 times
Re: BME688 ESP32 ESP8266 Rasberry PI AVR
Hi SpeedPIC32
Interesting component, I've looked at that too. This sensor should measure the air quality in rooms with many people
Major direct outputs: Index for Air Quality (IAQ), bVOC-& CO₂-equivalents (ppm), Gas scan result (%) & many more (all listed in datasheet in Table 20: BSEC outputs)
https://www.bosch-sensortec.com/media/b ... -ds000.pdf
SpeedPIC32
Hello Stefan Hello Ben
Can the sensor be integrated?
Environmental measurement technology is generally interesting.
The sensor is also quite cheap to get.
I would be happy if that would work.
SpeedPic32
Has thanked: 647 times
Been thanked: 856 times
I've ordered a module so I can have a play with it. Hopefully should arrive soon.
SpeedPIC32
Hello Ben,
I think that's good. I'm curious about the sensor and the possibilities.
Greetings SpeedPic32
I've started work on a component to go with this module and here is the code I have so far based on the code from the datasheet. I thought it best to share the source and then you can adjust it to your requirements and hopefully together we can build in the functionality and iron out any bugs.
I'm using one of my interface boards to allow me to communicate to the module directly from within the FC simulation saves compiling and programming for every change and addition.
https://www.instructables.com/Universal ... ace-Board/
You could use another API SLAVE target to do the same by replacing the component for another API component e.g. the Arduino Uno. Don't forget the I2C pull up resistors.
https://www.flowcode.co.uk/wiki/index.p ... ve_Devices
You could of course simply compile the code for a MCU as usual instead. It might be interesting to see how the various floating point calculations handle on the various embedded platforms.
I've currently only done temperature, pressure and humidity sensing macros but they seem to be giving sensible values.
Have a look and see what you think.
BME688 AirQualitySensor.fcfx
(57.83 KiB) Downloaded 778 times
Right I've gotten the component a bit further now so it can now set the temperature of the hot plate and do a gas resistence reading. I've exported the component and pushed it to the update system.
Let mw know how you get on if you have a go.
I have your interface boards since a long time ready.
Unfortunately, the sensor has a long delay and will arrive next week.
I'm still trying with the interface boards, but I'll also test the component on a PIC32 and an ESP32
Great thanks Stefan,
What's still not clear to me is how to set the temperature of the hot plate and use that to test for a specific gas and from that work out the air pollution level. This isn't in the datasheet so might need some playing with to get some good results.
I wonder if we can integrate with their tool too as it seems they draw additional conclusions from the various data such as liklihood of mould growth etc.
The Sensor came today. I have already made the wire connections and added the component to one of my ESP32 program. Unfortunately I can no longer compile error free with the component added.
Demodata_ESP32_bme688.fcfx
(105.26 KiB) Downloaded 641 times
