A general question
I have used Modbus many years ago so i know the general operation but have a question
Roughly how fast (order of magnitude) can i poll the slave and read back multiple 16bit holding registers (approx 16) from the ECIO using the set up below
The hardware i am using is
windows 11 7 core processor & APP developer
ECIO40P16 dspic
For fastest speed should i use serial RTU via the coms port or TCP/IP or ? (coms port would be easier for me if not much slower than TCP/IP ?)
The reason i ask is that the ECIO is monitoring and manipulating I/O ports locally continuously (ie micro seconds) ie very fast and i do not wish a
poll request to slow down this action as i could lose data whilst data is being sent backward / forward from slave to APP developer
Perhaps some interrupt philosophy could be used to help to interlace the relatively slow communication between the APP developer and the ECIO
fast local port monitoring and control any rough ideas or so
So before i start testing this in a hardware implementation on my bench any general hints / advice
Note i do realise that modbus is not the fastest protocol nowadays but for other reasons i would like to use it in this case
Best regards
David
MODBUS
DAVIDJOINER
- Been thanked: 18 times
DAVIDJOINER
Re: MODBUS
Hi Folks
Managed to answer my own question
Over the weekend i was able to set up a physical hardware system and with aid of a logic analyser and using additional
interrupts on the RX line and timers was able to reduce the max loading in the slave down to less than 0.3mS after detecting rx activity from a
master to single slave at 115200 baud
This will now be fine for me to incorporate into my project
David
David
DAVIDJOINER
Re: MODBUS
Hi Steve
Enclosed is a simple APP program for illustrating the point i was raising
The program scans 11 registers from Modbus slave 1 ( also updates the slave register 6 to test the writing)
This all works fine when connected to an ECIO40P16 running Modbus RTU at 115200 Baud
The issue i have is that the APP developer seems to have a fastest scan rate around .4 seconds
I would like to be able to scan around 100mS
I also note that the event comment in the APP has a minimum event time of 1 second ie i would like to be able to set it to 100mS as above
Any possibility to do this
Best Regards
David
Best Regards
David
- DAJ MODBUS APP TEST REV 0.fcsx
- (14.38 KiB) Downloaded 740 times
- (view online)
- Has thanked: 635 times
- Been thanked: 842 times
Re: MODBUS
Hi David,
The Modbus Master SCADA component currently reads data in until it gets a timeout to ensure it has collected everything. You could try reducing the UART Receive Timeout property and this should speed things up a bit. I'll see if I can rework the component a bit so that it doesn't rely on getting a timeout.
The Silent interval property also sets a delay in ms between messages so you can also reduce this to speed up the comms.
DAVIDJOINER
Re: MODBUS
Thanks for your comments
Have reduced further the receive and timeout properties and a bit better
Also as i said before is it possible to modify the APP event trigger to enter miili seconds rather than seconds as this would be better
Although do not reaaly want to but if i were to change to MODBUS TCP would that speed the overall screen response time or is it limited by the APP developer itself
David
David
Re: MODBUS
Hi David,
For millisecond based timed events it might be better to use the built in API timer, note that delays using this will be approximate and delays less than 50ms will end up being at least 50ms due to the nature of the Windows OS.
For the example I enabled the following events using the Events tab of the project explorer window:
System -> Timer - Ev_Timer - Performs the regular timed background event and rearms the timer.
Simulation -> Start - Ev_Start - Starts the timer running
Simulation -> Resume - Ev_Start - Starts the timer running
Simulation -> Stop - Ev_Stop - Stops the timer running
Simulation -> Pause - Ev_Stop - Stops the timer running
The rate of the timer is controlled via the TIMERDELAYMS constant.
The delay with using the serial modbus is down to the current need for a timeout, we should be able to remove this for you and then it should run much faster.
Re: MODBUS
I've pushed an update to the Modbus component onto the library update system for you. Hopefully it should improve things further.
Let us know how you get on.
DAVIDJOINER
Re: MODBUS
That's great now faster and suitable for my current Project needs
As an aside over next week or so i will also now try the MODUS TCP option using a ESP32 WROOM just to see if any benefits switching from my dspic33 to ESP32
Many thanks again
David
Many thanks again
David
