ESP32WROOM-32 programming issue "baud"
LeighM
Has thanked: 111 times
Been thanked: 302 times
Re: ESP32WROOM-32 programming issue "baud"
Post by LeighM »
We have both listed, as separate FCD files, the chip view is different and hopefully helpful :D
Has thanked: 311 times
Been thanked: 479 times
Regarding the original problem, it looks like the setting for the port is missing. The "project options" screen will show the first com port in the "programmer port" drop down as a default, but there is a bug where this is not actually set.
To ensure the com port is set correctly, open "project options", then click the drop-down and select the appropriate com port in the list (even if it seems already selected) and then click ok. Then save your project. At this point, the com port should definitely be selected and should also be saved in the project fcfx file. You can check this is the case by opening the "global settings" screen, and clicking on a dropdown in the "Locations" tab as shown in the screenshot below.
COMTEC_80
Been thanked: 1 time
Post by COMTEC_80 »
the trick works also for me and now i have programming chip.... but i have noted that before $(comport) in compiler option seem lack a " or i wrong?
LeighM
Post by LeighM »
Glad to hear you have it working.
The quotes are not needed in the case of the COM port because it does not contain a space
maatanen
Post by maatanen »
I have a slightly different error when uploading to the board
Target folder: D:\FlowCode_project
Source name: D:\FlowCode_project\Flowcode1.fcfx
Title:
Description:
Device: ESP.ESP32.ESP32_WROOM_32
Generated by: Flowcode v9.0.0.23
Date: Saturday, January 16, 2021 05:30:14
Users: 1
Registered to: maatanen (maatanen)
Licence key: at>
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_build.bat "C:\Users\Maatanen\Desktop\esp-idf\" "Flowcode1" "D:\FlowCode_project\" esp32s_sdkconfig
Building Flowcode1 ...
Setting IDF_PATH: C:\Users\Maatanen\Desktop\esp-idf
Adding ESP-IDF tools to PATH...
C:\Users\Maatanen\.espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin
C:\Users\Maatanen\.espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin
C:\Users\Maatanen\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
C:\Users\Maatanen\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
C:\Users\Maatanen\.espressif\tools\cmake\3.16.4\bin
C:\Users\Maatanen\.espressif\tools\openocd-esp32\v0.10.0-esp32-20200709\openocd-esp32\bin
C:\Users\Maatanen\.espressif\tools\ninja\1.10.0\
C:\Users\Maatanen\.espressif\tools\idf-exe\1.0.1\
C:\Users\Maatanen\.espressif\tools\ccache\3.7\
C:\Users\Maatanen\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64
C:\Users\Maatanen\.espressif\python_env\idf4.2_py3.7_env\Scripts
C:\Users\Maatanen\Desktop\esp-idf\tools
Python requirements from C:\Users\Maatanen\Desktop\esp-idf\requirements.txt are satisfied.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
[0/1] Re-running CMake...
FAILED: build.ninja
D:\FlowCode_project\.espressif\tools\cmake\3.13.4\bin\cmake.exe -SD:\FlowCode_project\Flowcode1 -BD:\FlowCode_project\Flowcode1\build
CreateProcess failed: The system cannot find the file specified.
ninja: error: rebuilding 'build.ninja': subcommand failed
Running ninja in directory d:\flowcode_project\flowcode1\build
Executing "ninja all"...
ninja failed with exit code 1
Build Failed
Autoclose turned off
FINISHED
I can't understand what is the reason.
LeighM
Post by LeighM »
That looks like a build failure, rather than a programming issue.
If you have not yet had any successful builds, then it is most likely that the toolchain has not installed correctly.
Please have a search for other posts regarding installation help and common problems related to it.
If nothing helps, please get back to us with more details and what you have tried.
