There seems to be an error in the Timer interrupt frequency calculation.
I created a small test program - using a pic16lf15313 running at 32MHz. I have a LED on a4 (with a current limiting resistor of course)
The Interrupt enable specifies a frequency of 1953Hz - but as can be seen from the check at the end - the frequency is ~8000Hz (actually it's its slightly > 8000 set check to 7800 - 8100 to light the LED!)
Modifying source to FOsc / 4 gives the same 'calculated' rate - and the correct rate in hardware.
Edit - it's probably just that fosc /hfintosc options shouldn't be offered?
PIC Timer interrupt calculation
- Has thanked: 177 times
- Been thanked: 1026 times
- Has thanked: 647 times
- Been thanked: 856 times
Re: PIC Timer interrupt calculation
Hmm that's strange maybe something for us to explore in the executable. Here is the XML from the definition file for timer 2 and it seems to be setting the clock divider (clkdiv) correctly to 0 when the selected source clock speed is unknown. Maybe Flowcode is incorrectly assuming a clkdiv of 0 is actually a clkdiv of 4.
Hmm even the clkdiv of 1 isn't working. Very odd I'll chase this up.
<option name='Clock Source Select' >
<entry name='Transition on T2CKI pin' clkdiv='0' value='T2CLKCON = 0;\n' />
<entry name='Internal clock (Fosc/4)' clkdiv='4' value='T2CLKCON = 1;\n' />
<entry name='Internal clock (Fosc)' clkdiv='1' value='T2CLKCON = 2;\n' />
<entry name='HFINTOSC' clkdiv='0' value='T2CLKCON = 3;\n' />
<entry name='LFINTOSC' clkdiv='0' value='T2CLKCON = 4;\n' />
<entry name='MFINTOSC 500KHz' clkdiv='0' value='T2CLKCON = 5;\n' />
<entry name='MFINTOSC 31.25KHz' clkdiv='0' value='T2CLKCON = 6;\n' />
<entry name='SOSC' clkdiv='0' value='T2CLKCON = 7;\n' />
</option>-
- Has thanked: 311 times
- Been thanked: 479 times
I've looked into this and it appears that the "clkdiv" override on the clock source entries in the FCD are totally ignored by Flowcode and instead the "master_divider" entry is used.
There is no simple fix. I'll add it to my list to investigate, and hopefully there will be a fix in a future release of Flowcode.
A quick update on this. I have fixed this issue and it will be fixed once v10 has been released. We expect this release before the year end.
