RTC_ESP32_NTP1
jollybv
Has thanked: 42 times
Been thanked: 15 times
RTC_ESP32_NTP1
Post by jollybv »
Hi Guys
I'm looking for an example on how to use the ESP Real Time Clock component. I have been to the wiki help page and the download example is not downloading it just opens and shows you the code
https://www.flowcode.co.uk/wiki/index.p ... _(Storage)
Has thanked: 163 times
Been thanked: 960 times
Re: RTC_ESP32_NTP1
Post by mnfisher »
This looks like a formatting error on the page. You can copy all the text - save as a file with .fcfx extension and it will open okay. Until the wiki is fixed - hopefully fairly soon?
jollybv
Re: RTC_ESP32_NTP1
Post by jollybv »
Thanks Martin
Copping and saving with .fcfx worked but it wont compile just get error the only thing I have don is change the esp device to the esp 32 wroom so no idea why this simple example wont compile.
RTC Compile fail 1.txt
(25.27 KiB) Downloaded 600 times
ESP32_RTC_NTP_Example.fcfx
(14.37 KiB) Downloaded 636 times
Re: RTC_ESP32_NTP1
Post by mnfisher »
This has been reported before - there was a problem with the TimeVal structure missing from the component. I'm sure Ben - mentioned fixing this....
There is a working example from Stefan somewhere -
See https://www.flowcode.co.uk/forums/viewt ... =esp32+ntp
& https://www.flowcode.co.uk/forums/viewt ... =esp32+ntp
I think the sample I saw originally defined TimeVal in supplementary code - though if it's been added to the component it shouldn't need this..
jollybv
Re: RTC_ESP32_NTP1
Post by jollybv »
Hi guys
I have just downloaded the RTC_ESP32 example from the above thread and it does not seem to want to compile. I have done a full library update with no luck (I'm using the ESP_32 WROOM instead of the Loin32 lite selected in the example).
I'm getting 2 error's
../main/esp-project.c:230:15: error: expected identifier or '(' before string constant
#define TAG "rtc"
../main/esp-project.c: At top level:
../main/esp-project.c:271:6: error: redefinition of 'time_sync_notification_cb'
void time_sync_notification_cb(struct timeval *tv)
(25.25 KiB) Downloaded 532 times
Has thanked: 616 times
Been thanked: 815 times
Re: RTC_ESP32_NTP1
Many thanks for letting us know.
I have removed the compilation error for you now and updated the component via the library updates.
I can also confirm that the code in the supplementary code window can also be removed as shown here.
RTC_ESP32.fcfx
(14.43 KiB) Downloaded 559 times
jollybv
Re: RTC_ESP32_NTP1
Post by jollybv »
Thanks the time is working like a dream.
