Hi Guys
Ben your Display is ILI9488 ? I cant yet working ILI9488 in SPI mode
STM32-SPI-ILI9488
mehmet64
- Has thanked: 8 times
- Been thanked: 4 times
- Has thanked: 523 times
- Been thanked: 710 times
Re: STM32-SPI-ILI9488
Hi Jorgen,
I've spent time on this yesterday and again today. I have made some progress but it's still not fully working. I have been able to set pixels but only from a light grey to black and not back again.
I've changed the colour from 565 to 666 format as required by the ILI9488 in SPI mode but still no joy.
I've been copying some online libraries and what I have should be working but isn't I'm now wondering if there are different versions of the driver as I've heard mention of this on a forum. Do you still have a link to where you purchased the display from?
I'll keep trying next step might be to try and get the MISO working so I can read back from the display and this will hopefully allow me to confirm the driver IC I'm dealing with.
jgu1
- Has thanked: 743 times
- Been thanked: 186 times
Hi Ben!
Well ok, tricky display, I though it was almost similar with few change to the Ili9341
If I use the ILI9341 display with Ili9488 component SPI the Ili9341 work, but not 100%
Unfortunately I can´t remember where I bougth the display, I think it was on Ebay somewhere.
Edit, found it here: https://www.ebay.de/itm/1pc-3-5-Zoll-48 ... 2411b818ed
Maybe mehmert can help, where do you buy yours?
Jorgen
Jorgen
jgu1
Hi Ben!
Could some this be useful or help:
http://www.lcdwiki.com/3.5inch_SPI_Modu ... KU:MSP3520
https://pdf1.alldatasheet.com/datasheet ... I9488.html
Jorgen
Jorgen
I did have another go on Friday and over the weekend. I went through the register initialisers from the library I was using and compared them to the datasheet and they were all over the place in terms of either not matching up the correct number of parameter bytes or calling functions that weren't there, on my version of the datasheet anyway. So I've stripped out everything that is wrong and I'll try and move forward using defaults and switching individual settings on and off to see if it makes a difference.
I also implemented the register readback so I can monitor the setup of the LCD once everything has been initialised. This should hopefully allow me to play with the settings until I stumble onto a setup that works.
Hopefully I'll get more time on it tomorrow.
