OLED SSD1306 I2C Address
jgu1
Has thanked: 877 times
Been thanked: 214 times
Re: OLED SSD1306 I2C Address
Post by jgu1 »
Hi all!
I report a bug for these tiny display In Fc9for a while ago. Do you have FC8, try to make a test in this SW work fine there, But not in FC9. ;)
viewtopic.php?f=3&t=790
Br Jorgen
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
I think it's a strange timing problem. And that could be the reason the display is updated very very slowly (like 1 minute to draw a small text on the display or clear the display).
These are screenshots from my logic analyser with several different settings for the I2C baud rate:
Baud rate in SSD1306 I2C properties = 100kHz
Baud rate in SSD1306 I2C properties = 400kHz
Baud rate in SSD1306 I2C properties = 1MHz
Even with a custom baudrate it keeps 490hz...
I hope that with this information Matrix can fix this problem really fast.
MJU20
Post by MJU20 »
And this is with the Arduino/ESP32 library with Adafruit sketch..
This one works..
jgu1
Post by jgu1 »
Hi MJU
Well spottet :D So I was rigth viewtopic.php?f=3&t=790
Have you testet in FC8 (Arduino) it works there
Jorgen
MJU20
Post by MJU20 »
Not tested in FC8 because this project has to work with an ESP32 and that wasn't supported in this version.
BTW: I think this problem may occur in the SPI version too. I've tested the ESP with the SPI version of the SSD1306 and this also didn't work..
Has thanked: 634 times
Been thanked: 838 times
With the I2C timing problem you've highlighted. Please can you confirm the target MCU you're using and also the I2C channel you're using and I'll investigate for you.
MJU20
Post by MJU20 »
Thank you Ben,
I'm using an (NodeMCU) ESP-Wroom-32 (version 1.1).
The I2C channel I'm using is "software" on pin A21 (SDA) and A22 (SCL). (same as the Arduino sketch)
BTW: I2C Channel 1 in FC proposes pin B4 on the board (A36), but this is not available on the board.
MJU20
Post by MJU20 »
:oops: any news on this one?
LeighM
Has thanked: 107 times
Been thanked: 302 times
Post by LeighM »
Using software aka bitbang I2C is very much a last resort on ESP32 due to it running an RTOS, hence timings can't be guaranteed and tend to stretch considerably.
Are there any hardware channel I2C remap pins that you can use?
MJU20
Post by MJU20 »
I will look into remapping the I2C.
Too bad it took a week to read this and meanwhile the display was tested with an Arduino sketch using the same IO's as those I used with FC. :shock:
