Could PrintFormattedNumber be added to all displays and not just LCD?
Then gLCD can display Long and Ulong numbers, rather than restricting to signed Ints e.t.c.
Print Formatted Number
- Has thanked: 538 times
- Been thanked: 487 times
- Has thanked: 458 times
- Been thanked: 624 times
Re: Print Formatted Number
Good suggestion thanks. I'll have a look shouldn't be too tricky to do![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
While I'm at it what about a print float function with number of floating points param?
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
This is always useful never mind the application LCD,gLCD even in Serial coms
- Has thanked: 175 times
- Been thanked: 299 times
I realise it's an extra step, but you can always convert the float to a string in a calculation and use the string if the component can't handle the float.
