UART Console
geomanfred
Has thanked: 5 times
Been thanked: 1 time
UART Console
Post by geomanfred »
I try to learn by following the examples from next Flowcode Wiki pages:
https://www.flowcode.co.uk/wiki/index.p ... Interface)
https://www.flowcode.co.uk/wiki/index.p ... Injectors)
For example I take “RS232_Example2.fcfx” and when I simulate then the Console tabs disappears.
What do I do wrong?
My intention is to use Flowcode with Arduino and to get some ASCII from real Arduino on screen/console via USB/serial port in the same manner as I get “Serial Monitor” in IDE Arduino environment.
Can I achieve that with Flowcode and its Console?
UART before Simulation.png (187.52 KiB) Viewed 7887 times
Injector before simulation.png (173.63 KiB) Viewed 7887 times
Console during Simulation.png (170.13 KiB) Viewed 7887 times
Has thanked: 442 times
Been thanked: 661 times
Re: UART Console
Post by chipfryer27 »
Are you running FC v9.3 or 9.2 (check by clicking the question mark in top right).
If v9.3 then I think it may already be a known issue.
geomanfred
Re: UART Console
That is version 9.0.35
Re: UART Console
I would try upgrading to latest version to ensure you are up to date with everything. This can be done by opening Global Settings and checking the "Check for Core Updates" box.
Easier for Matrix to assist (if needed) if you are using latest version.
Has thanked: 724 times
Been thanked: 783 times
Re: UART Console
Thanks for the report.
This is currently being looked into.
Has thanked: 616 times
Been thanked: 815 times
Re: UART Console
The problem should be fixed for you now using the latest v9.3 release and also going to Help -> Library updates and downloading the latest components. Might be worth doing a full database update to get all the latest components and bug fixes.
geomanfred
Re: UART Console
But I use the latest version 9.3.0.35.
Sorry was my mistake above with 9.0.35.
And I have updated all the latest components.
Re: UART Console
I've just downloaded the RS-232 Example-2 from the website and it runs without issue for me. All expected tabs are shown in the console.
Stupid question and sorry to ask but have you altered the chart in any way? Maybe accidentally switched something off or the like?
Perhaps post the chart you are using and I'll see if it has any issues for me.
geomanfred
Re: UART Console
Attached is the example that I have used.
But now the problem is solved.
It came up a notice in this morning to update the components as you can see in the attached picture below.
I have tested the example before update and did not work properly.
After update it works properly.
The problem is solved.
Flowcode 9 UART update.png (145.1 KiB) Viewed 7773 times
RS232_Example2.fcfx
(11.13 KiB) Downloaded 540 times
geomanfred
Re: UART Console
But in the end, I do not know if I can achieve a similar “Serial Monitor” as in Arduino IDE.
Do I have to use an external software to monitor the serial port, which is in fact my USB programming port of Arduino?
Or can I see all the data inside to Flowcode Console?
I also see next application example:
https://www.flowcode.co.uk/resources/da ... 20V1.0.pdf
But does not seem to do exactly as the “Serial Monitor” does in Arduino IDE.
