Attiny 88
Sergejs
Has thanked: 75 times
Been thanked: 5 times
Attiny 88
Post by Sergejs »
Hi everyone! Is it possible to make Tiny 88 support in V9 ?
Has thanked: 478 times
Been thanked: 713 times
Re: Attiny 88
Post by chipfryer27 »
I thought it's already supported?
New Project > AVR Based > ATTiny shows the 88 and 88TQFP
Hope this helps
Sergejs
Re: Attiny 88
Post by Sergejs »
But I can not connect it. I have not drivers or something else. There is "Unknown USB device".
Sergejs
Re: Attiny 88
Post by Sergejs »
I ask about this item from Ebay.com:
Attiny88_PCB
Attiny88_PCB
Has thanked: 246 times
Been thanked: 258 times
Re: Attiny 88
Hi Sergejs
To make your Attiny88 work with Flowcode,
I assume you need a USB driver for the Attiny88 for your windows system
You can find and install this online.
search for: USB driver Attiny88 windows
Has thanked: 649 times
Been thanked: 856 times
Re: Attiny 88
USB could just be for power, I don't think the tiny88 is capable of USB comms and I'm not seeing an external USB IC though it could be on the underside.
It looks like there is the standard 6-way socket towards the top of the board for an AVRISP or USBtinyISP to allow programming.
A link to the eBay sales page might help.
Sergejs
Re: Attiny 88
Post by Sergejs »
BenR wrote: ↑
Mon Sep 26, 2022 3:01 pm
This link is PCB like I have now:
https://www.ebay.com/itm/234497208159?h ... R6DSkqbvYA
Re: Attiny 88
Ok So it's a ATmega328 which doesn't have hardware USB, I beleive you can bit bang USB on an AVR but I certainly wouldn't recommend it.
Certainly the standard Arduino bootloader won't work as that uses a UART and a USB to Serial external IC.
So it looks like you will need an ISP programmer to reprogram the thing and you will have to be careful about which IO you toggle when powered via USB.
