ESP32 Real Time Clock faild
Has thanked: 246 times
Been thanked: 257 times
I would like to use the RTC of the ESP32 without wifi. But when I initialize the component I get a "failed"
ESP32 RTC
Has thanked: 637 times
Been thanked: 847 times
Re: ESP32 Real Time Clock faild
Hi Stefan,
I beleive if you add the wifi component, even if you're not using it then hopefully that should allow the compilation to complete.
I'll investigate and see if there is a way to allow the build regardless.
Yes with the wlan the RTC works.
I can also set the time with the server. All this is with Flowcode very easy to do
But with the wireless connection, the HX711 no longer works properly. Is there a way to do the waln like unconnect or can you add a dissconnectSSID command for the wlan.
That would be useful if you only need the wifi for a short time.
Hi Stefan,
You can disable interrupts for a while on the ESP32 by using this in a C icon. Do you want to try adding this just before sampling the HX711 and hopefully that should solve the problem for you.
c code icon
portDISABLE_INTERRUPTS();
HX711 sample
c code icon
portENABLE_INTERRUPTS();
If it works for you then I'll put the code into the time critical part of the component.
Unfortunately, disable interrupts is not an option for my program
this would be my wish...
Setting the time and date with WiFi, USB or Bluetooth
The time is set via Wlan:
If I press a button when starting up, it should turn on wifi and set the clock and date. Then the wifi should be turned off again. with an additional command disconnect SSI)
The time is set via USB or Bluetooth:
For this I wrote FC9 APP where it already works well. Sending the PC timeDate to the ESP32
with an additional command set TimeDate string while Wlan is turned of
read the time and date:
If the ESP32 starts normally I should be able to read the time and date. Just read one string is enough.
with an additional command get TimeDate string while Wlan is turned of
I will test if the ESP32 let the time run in deep sleep mode. Unfortunately I did not find a pin for an additional battery for RTCC
Hi Stefan,
We can certainly look at adding a disconnect macro. Does the following C code do what you need?
 esp_wifi_disconnect();
 esp_wifi_stop();
 esp_wifi_deinit();
Yes it's working fine.
If the password is correct it's set the time (with 2hours offset)
If the password is bad it's set the time to 00:00:00 ( 2hours offset is set to 0)
Always the HX711 is working nice.
These 3 commands could also be useful for other applications, if it is not too complicated I would add them to the component.
But for me it's already perfect.
One more reason to turn off the wifi when not in use.
A Board with Esp32, display various hardware and wlan connected, needs 165mA
If I do the commands to disconnect wlan, the board just needs 120mA
If I use a deepsleep command , the board needs 10mA and the clock(time) keeps running
But after a reset (power off), the time must be set again
