Good day I'm trying 2 arduino micro with 2 w5500, the server side works perfectly from any pc I see the page updates, with the client side 2nd arduino I try to view the return data by sending them in uart but I always receive page not found I followed the example in the wiki you propose but it doesn't work.
How could I solve? Thanks 1000
I am attaching the fc files
W5500 client not work
hiromiyureei
- Been thanked: 5 times
- rs232.PNG (33.18 KiB) Viewed 3335 times
- Client Contact.fcfx
- (35.75 KiB) Downloaded 295 times
- (view online)
- Server Contact.fcfx
- (30.4 KiB) Downloaded 326 times
- (view online)
- Has thanked: 649 times
- Been thanked: 856 times
Re: W5500 client not work
In your client program when you perform the GET operation you are sending a length of 14, should this be longer to account for the full string, I beleive 23 would be a better value.
hiromiyureei
Yes I had already tried with 23 and even longer but it does not change.if I try to scan the network I see that 222 calls 223.
server 222 and client 223
- eth.PNG (100.68 KiB) Viewed 3322 times
