50Hz Ammeter on PIC16F628A
Sergejs
Has thanked: 75 times
Been thanked: 5 times
Post by Sergejs »
How much samples is need and how much uS time between it to stable read AC current from shunt connected to port of MCU?
Voltage is 230V and net frequency is 50Hz (Eastern Europe). If possible diagram please.
Sergejs
Re: 50Hz Ammeter on PIC16F628A
Post by Sergejs »
I put here my project for best understanding.
Ammeter_01.fcfx
(10.74 KiB) Downloaded 388 times
Has thanked: 650 times
Been thanked: 856 times
It's hard to say without seeing your circuit. Do you have any hardware filtering on the input such as R/C low pass filters.
Best thing might be to hardware filter as much as possible and then run your ADC result through a software median filter followed by a low pass filter and this should give you a fairly stable result.
I would start with playing around with the settings you mentioed to try and get as stable an output as possible and then you can add the additional filters to get a highly stable value.
