would it be possible to get support for PIC16F17126/46
and PIC16F18026/46 for flowcode 8 and flowcode 9?
This are new PICs, large memory, smal pincount.
thank you
Dirk
Support for PIC16F17126/46 and PIC16F18026/46
DirkB
- Has thanked: 1 time
- Been thanked: 4 times
- Has thanked: 633 times
- Been thanked: 837 times
Re: Support for PIC16F17126/46 and PIC16F18026/46
Hi Dirk,
Those devices aren't currently supported by the compiler we're providing. I'm looking at a new version of the compiler for use with v10 and so I'll see if I can get those devices supported there for you.
Hello Ben,
I use the compiler xc8 Ver. 2.40 with FC8.
That's why I use FC8 the most at the moment.
It is much faster and the hex file is 30% smaller.
I have attached the batch file for FC8. How
can I use xc8 Ver. 2.40 in FC9? With the
I have not been able to get it to work with the same batch file.
The paths are different. The batch file is attached, just
rename back to pic_xc8_comp.bat.
thank you
Dirk
thank you
Dirk
- pic_xc8_comp.txt
- (338 Bytes) Downloaded 421 times
