Assembler
keithh534
Assembler
Post by keithh534 »
Are there any plans to include an "Assembler" Command Icon for writing Assembly code for Microchip MCUs?
Has thanked: 311 times
Been thanked: 479 times
Re: Assembler
You can add assembly language within a C icon using "#asm" or "asm()" like this:
#asm
 BCF 0,3
 BANKSEL(_var)
 RLF (_var)&07fh
 RLF (_var+1)&07fh
#endasm
 // or alternatively:
 asm("BCF 0,3");
 asm("BANKSEL _var");
 asm("RLF (_var)&07fh");
 asm("RLF (_var+1)&07fh");
Has thanked: 246 times
Been thanked: 258 times
Re: Assembler
Hi keithh534
Assembly code for Microchip MCU is not for all PIC the same. PIC32 has a different assembler code.
What I can recommend to you is to use Flowcode's C code for the PIC32 to set and get some register.
keithh534
Re: Assembler
Post by keithh534 »
Thank you!
