MMA8452 Errors when generating C source code
Terminator_123
Been thanked: 1 time
Post by Terminator_123 »
I use the MMA8452 with the ATtiny2313 microcontroller (and tested with pic16f628a). I get an error message when generating code C. I may have found an error, see the attached screenshots
Has thanked: 795 times
Been thanked: 858 times
Re: MMA8452 Errors when generating C source code
Thank you for the spot.
I have replicated and fixed the issue, and the component will be pushed onto the update system as soon as possible.
If you would like to try the components before the updates are pushed.
C:\ProgramData\MatrixTSL\FlowcodeV9\Components
If you run any component updates, then the components you added will be overwritten with the updated version.
Accelerometer_MMA8452Q.fcpx
(6.37 KiB) Downloaded 147 times
Terminator_123
thanks, it worked
That's great.
Thanks for letting me know.
