Failure to optimize APP DEVELOPER will put a heavy load on the computer
VIDEOMED
Post by VIDEOMED »
I did App Developer tests.
I wanted to test the way it works.
The program does nothing but displays the text TEST.
To my surprise, a fairly strong laptop turned on the cooling system.
I checked the system load and I am terrified.
Pictures of the system load are attached. And a test program
Flowcode test 0.fcsx
(7.75 KiB) Downloaded 432 times
Has thanked: 311 times
Been thanked: 479 times
Re: Failure to optimize APP DEVELOPER will put a heavy load on the computer
I believe you can limit the amount of power Flowcode and its deployed apps use on a laptop by adjusting the Power Throttling settings (in Windows 10).
Flowcode (and its deployed apps) will use as much CPU as is available, but is designed to limit this and should not interfere with the operation of the OS or other running applications. If you do find the performance of other applications is affected by Flowcode or one of its deployed apps then you can change its priority via the Windows Task Manager.
