Analg read
Amrat
Has thanked: 1 time
Analg read
Post by Amrat »
I set potentiometer connect to A0 with GETBYTE and decision IF Getbyte>128 LED TurnON
When simulate its is OK but when to compile to target, LED always turn on ???
Someone please explain
Amrat
Has thanked: 756 times
Been thanked: 819 times
Re: Analg read
An issue like that is when the potentiometer VRef voltage properties is set to vref+ instead VDD and Vref+ pin is left floating.
If that is not the case can you post your project file that has extension .fcfx
Amrat
Has thanked: 1 time
Re: Analg read
Post by Amrat »
Thanks for your reply. About set parameter Vref I confused as no explanation on Wiki. Will you please send sample base on my fcfx file ? then I will understand.
Thanks in advance
Attached is simple file I do test.
Thanks again
Amrat
Arduino KitOnShield.fcfx
(10.51 KiB) Downloaded 594 times
Re: Analg read
I have modified your project by changing Vref option from the default AREF to AVCC.
Changing Vref option.png (78.27 KiB) Viewed 6358 times
Additionally, I have increased the conversion speed to Fosc/128 for extra stability.
I have also added a note on wiki for each potentiometer.
Arduino KitOnShield v2.fcfx
(10.51 KiB) Downloaded 640 times
Amrat
Has thanked: 1 time
Re: Analg read
Post by Amrat »
Again need some advice.
How to program to read Analog Voltage of Microphone ? as in component libraries have no mic !!
Thanks in Advance
Best rgds
Amrat
Has thanked: 468 times
Been thanked: 697 times
Re: Analg read
Post by chipfryer27 »
It depends on your application.
There is a component to measure strength of background sound levels, but if you are looking to record your voice or such like then things get a little more complicated and component speeds are critical to success.
Generally speaking you would need to take a reading (sample) at twice the highest frequency you wish to capture. As an example, analogue telephones have a bandwidth of 4KHz (being 300 - 3400Hz + gaps) therefore we would need to sample at 8KHz to stand a reasonable chance of recording / transmitting recognisable speech.
Whilst that works out at a sample every 125uS you have to take the time taken to actually sample and store / do something with the sample into consideration too.
