ESP32 and servo controller/ ninja failed with exit code 1
Has thanked: 618 times
Been thanked: 818 times
Re: ESP32 and servo controller/ ninja failed with exit code 1
Hi Dirk,
Via C code using the servo controller component might be possible yes.
Try this function out.
FC_CAL_PWM_ChangeFrequency_1(100);
Where _1 is channel 1 and 100 is 100Hz duty.
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
....mh OK!! Putting that statement in a C Box will come back with a compiler error. It will not compile.
I assume the ESP32 C Box code is may differnt.
BR
Dirk
Happy FC9, FC-8 and FC-6 professional user ;)
dvcam99
Post by dvcam99 »
Hi Ben,
additional feedback. I just tried to open up a second servo controller in order to get at least 16 servo channels.
Then you get a compiler error again.
So is the limit 8 channels??
BR
Dirk
dvcam99
Post by dvcam99 »
Hello Ben,
I have tested the servo controller further on.
If I assign two servos compiles perfectly like with one servo
If I assign 3 servo channels in the servo controller, complier quits with a error.
ESP32_Test_Servocontroll_3CH.fcfx
(11.65 KiB) Downloaded 648 times
BR
Dirk
Hi Dirk,
The servo count is limited to 8 channels at the moment but in theory we could get this up to 12 on the ESP32 hardware. Let me know if this would be useful.
I tried to replicate the problem with 3 channels but it compiled correctly for me. Please can you attach the msg.txt file from the failed compilation and I'll have a look at what caused your error.
Adding the C code to set the freuency to 100Hz also worked ok for me. I've attached your current program with the c code in place to make channel 1 100Hz. Note that channels 1 and 2 share a timer and hence will probably always run at the same rate. Same goes for channels 2 and 3 etc.
(11.87 KiB) Downloaded 674 times
dvcam99
Post by dvcam99 »
Hi Ben,
attached the message file from compiler:
ESP32_Test_Servocontroll_3CH.msg.txt
(14.27 KiB) Downloaded 710 times
Yes 12 Servo channel would be perfect and great.
I`ll check your modified file. I´ll come back with a feedback.
BR
Dirk
dvcam99
Post by dvcam99 »
Hi Ben,
your modified FC9 file with the 100Hz C-Box comes with a compiler error too at my installation.
Attached the message file:
(157.03 KiB) Downloaded 740 times
Very strange that it runs at your side. May some wrong compiler settings at my installation??
BR
Dirk
dvcam99
Post by dvcam99 »
Hello Ben,
Hello Matrix Team,
with the latest FC9 Update from today it now compiles with more then 2 servos assigned in the controller.
The C-code for different frame rates compiles OK too.
Many thanks!!
Dirk
dvcam99
Post by dvcam99 »
Hello Ben,
today I like to come back the the possibilty of 12 Servos outputs with ESP32. Do you have any news on this topic.
BR
Dirk
