ESP32 problem with components
Has thanked: 647 times
Been thanked: 856 times
Re: ESP32 problem with components
Ok thanks for comfirming, doing a compile test now to double check things this end.
edit - I've got the same problem. On with trying to resolve it for you now.
Should be all sorted for you now with the latest RMT component via the update system.
Thanks for bringing the issue to our attention.
Has thanked: 246 times
Been thanked: 258 times
Perfect! It's compiling and working again.
A little hint, the Led's only light up when I do a little delay after the drawline and before the refresh.
And there is an another litle problem with ESP32 and a component what I can not solve...
The HX711 component is alway give back 0.
https://flowcode.co.uk/forums/viewtopic.php?f=3&t=480
FC9_M5STACK Modul Atom Matrix_empty.fcfx
(11.33 KiB) Downloaded 451 times
