Which FC9 ADC component use for ESP32 ?
Has thanked: 724 times
Been thanked: 783 times
Re: Which FC9 ADC component use for ESP32 ?
Hi.
Thanks for bringing this to our attention.
There are indeed a couple of things that required changing, including the Bool.
The SetProperites function should not be used as its simulation only, it will not affect your hardware.
If you look at the icon shape, there is a difference between Sim only and embedded:
The component icons that have jagged edges won't change anything on your hardware.
For your reference:
All the properties are controlled by the manufacturer.
For example, there is no external reference pin on an ESP32.
It looks like there are only two set speeds, one high and one low, hence just showing Fixed.
The Vref for ESP32 is what you see on the list - See this external page.
