Thermistors
Has thanked: 795 times
Been thanked: 858 times
Re: Thermistors
I have made some changes to correct the issue.
Before the component is pushed onto the update system, would you like to test it first?
To do that, Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Replace the existing files with the attached file.
If you run any component updates, then the components you added will be overwritten.
Thermistor.fcpx
(83.83 KiB) Downloaded 422 times
WingNut
Has thanked: 56 times
Been thanked: 43 times
Re: Thermistors
Post by WingNut »
Hi Martin. I wont be able to do that until later tonight
Re: Thermistors
Hi.
Not a problem.
Thanks for letting me know.
WingNut
Re: Thermistors
Post by WingNut »
Thats working Martin except that the temp displayed never goes above 125°c
WingNut
Re: Thermistors
Post by WingNut »
Is there a fix for the temp returned not going above 125 °c?
Re: Thermistors
I have just looked at the source code for the thermistor component.
You can't change beyond the -25 and 125 points.
That's how it was designed by the component creator.
It's temperature setpoints that are stated on the datasheet.
The temperature is then calculated by linear interpolation, so it will start to become widely out of tolerance if above or below the highest and lowest set points.
If you want to go beyond the range which is not recommended, then you can try a different thermistor temperature calculation method.
For that, you will need to find its beta value, often given within a datasheet.
There is no upper or lower limit.
Thermistor Temperature Measurement v1.0.fcfx
(17.69 KiB) Downloaded 522 times
WingNut
Re: Thermistors
Post by WingNut »
Thanks Martin. I'll look into the formula. The thermistors I have are for the hot end of a 3d printer (1ook at 25°c) so theoretically can achieve over 200°c but I appreciate this is beyond the standard range. The datasheet I have is for 100k thermistor but doesn't go beyond 125°c either so I'll need to dig around on tinternet
