Thermistors
WingNut
Has thanked: 56 times
Been thanked: 43 times
Flowcode v10 Thermistors
Post by WingNut »
I've attached a sample program which I think is a bug. Using 2 thermistor components it dosn't separate the 2 devices. Thermistor 1 seems to be the only one which change the temp output and does it for both
2 thermistors test.fcfx
(14.17 KiB) Downloaded 704 times
Has thanked: 311 times
Been thanked: 479 times
Re: Thermistors
Thanks for the sample program - it shows the problem succinctly and should help us resolve the issue.
WingNut
Re: Thermistors
Post by WingNut »
Thanks Steve. Little more info - when you add the second thermistor it 'connects' it to the same analogue input (AN13)
Has thanked: 795 times
Been thanked: 858 times
Re: Thermistors
Many thanks for the spot.
I have fixed the issue and an update will be pushed on the update system, hopefully, today.
I will let you know when the update is pushed.
Re: Thermistors
The updates have now been pushed.
After updating the component database, you will need to reload your project for the effects to take place.
Re: Thermistors
Is your project working for you now?
WingNut
Re: Thermistors
Post by WingNut »
Sorry Martin it seems to work but then it alternates between one reading then the other
Re: Thermistors
I saw that too, but then noticed they were both connected to the same analogue input. Try setting them to different analogue inputs and it should work for you.
WingNut
Re: Thermistors
Post by WingNut »
Yes. Thats odd as I had separated them to AN14 and 13. I mentioned that in the post above. However, yes its now working on the smaller program
WingNut
Re: Thermistors
Post by WingNut »
However, :) you cant change the range displayed on the 2d panel it remains as the default of -25 and 125. I want to change this and the various resistance readings to match a 100k thermistor i have but the panel icon still remains as -25 and 125. The label doesn't change either
