Thermistors
WingNut
- Has thanked: 47 times
- Been thanked: 37 times
Thermistors
I've attached a sample program which I think is a bug. Using 2 thermistor components it dosn't separate the 2 devices. Thermistor 1 seems to be the only one which change the temp output and does it for both
- 2 thermistors test.fcfx
- (14.17 KiB) Downloaded 645 times
- Has thanked: 247 times
- Been thanked: 402 times
Re: Thermistors
Thanks for the sample program - it shows the problem succinctly and should help us resolve the issue.
- Has thanked: 685 times
- Been thanked: 759 times
Re: Thermistors
Many thanks for the spot.
I have fixed the issue and an update will be pushed on the update system, hopefully, today.
I will let you know when the update is pushed.
Re: Thermistors
I saw that too, but then noticed they were both connected to the same analogue input. Try setting them to different analogue inputs and it should work for you.
Re: Thermistors
However,
you cant change the range displayed on the 2d panel it remains as the default of -25 and 125. I want to change this and the various resistance readings to match a 100k thermistor i have but the panel icon still remains as -25 and 125. The label doesn't change either
