App Developer: USB Webcam Component
Has thanked: 294 times
Been thanked: 458 times
Re: App Developer: USB Webcam Component
I think that saving a file from a web app will always save to the Downloads folder (otherwise a website could compromise the local file system).
The attached is a small improvement. There is a new WebCamera fcpx component, and the ".fcweb" file is an example that sets the aspect ratio of the snapshot image to the same as the video and also saves the image (to the "Downloads" folder).
WebCamera.fcpx
(3.32 KiB) Downloaded 59 times
WebCamera.fcweb
(18.79 KiB) Downloaded 59 times
Has thanked: 236 times
Been thanked: 252 times
it's working very nice
The buttons can also be placed in the image, also the photo you've taken can be smal in the imagel.
To save the photo immediately, all I have to do is enter the macro command.
Autosave:
The files are perfect.
I have a small problem with the time—it's showing two hours too early, and I haven't been able to find a setting to fix it.
Thanks, Stefan.
The date is UTC. Here is some code that will hopefully set the filename to the local time. This will replace the code int he first icon in the OnSaveImageClick macro.
var currentdate = new Date();
//adjust for local time
var offset = currentdate.getTimezoneOffset();
currentdate.setTime(currentdate.getTime() - (offset*60*1000));
FCL_SFILENAME = currentdate.toISOString();
FCL_SFILENAME = FCL_SFILENAME.replaceAll("T", "_");
FCL_SFILENAME = FCL_SFILENAME.replaceAll(":", "-");
FCL_SFILENAME = FCL_SFILENAME.substring(0, 19);
FCL_SFILENAME = "PIC_" + FCL_SFILENAME + ".png"
The new lines are the 2 after the comment "adjust for local time".
Has thanked: 444 times
Been thanked: 665 times
Hi Steve / Stefan
Very interesting posts.
Keen to hear more on how you get on as I think this will be a great component once released.
Hi Steve, Hi Lain
Yes, that's a useful feature and it works well.
The time is correct now.
It would also be helpful if I could send a command from the PC App to the Web App to take the photo.
Both programs are running on the same computer.
This may not be possible due to the way web browser security works. Activity such as using the camera and saving files cannot be automatic and must be initiated via a user gesture (e.g. a mouse click).
Hi Steve
If two cameras are connected, would it also be possible to choose which one to use?
Would it also be possible to record a video?
Only about 60 seconds long.
I think when the web app asks for permission, you can choose the camera then.
I have just created a project which records and saved a video, so yes it can. But it has thrown up various issues. I will try to allocate some time to fix these issues over the next few days.
Hi Steve
Firefox ask for permission, and which camera
Edge ask for permission, but not for which camera
For the Edge The camera you can choose if you type in edge line_
edge://settings/content/camera
I added a second camera to the Web App
So I can use 2 cameras at the same time
“Record Video” will be missing soon :)
Hi Stefan (and anyone else who is interested).
I've spent a bit of time on this recently and attached is a components for a video control in Flowcode's Web Developer. This can also be attached to a web camera.
There is also an attached project which allows still images and short video clips to be taken and saved to the PC . It's similar to my previous example in this thread, but uses this new 'video' component instead and it is much simpler to use. An exported version of this project is here:
https://www.flowcode.co.uk/example/WebC ... mera4.html
WebCamera4.fcweb
(25.57 KiB) Downloaded 73 times
WebVideo.fcpx
(5.87 KiB) Downloaded 57 times
