Arduino Uno connection to ILI9341 TFT LCD
Has thanked: 107 times
Been thanked: 302 times
Re: Arduino Uno connection to ILI9341 TFT LCD
Hi Monie,
Have you installed the AVR/Arduino toolchain and checked the AVR toolchain location path in the Global Settings?
monie
Has thanked: 1 time
Post by monie »
Regarding: ILI9341 TFT display with Arduino
Attached Diagram:
ILI9341 TFT display with Arduino.pdf
(111.94 KiB) Downloaded 846 times
I'm trying to get ILI9341 TFT display, to work together with Arduino Uno R3
Do you have a simple Flowcode v10 Code example, that can be tested with Arduino Uno R together with ILI9341 TFT display.
Compiler Messages:
Compiler Messages 27-06-2023.pdf
(58.35 KiB) Downloaded 757 times
See Compiler Messages, at the bottom of the document, above here!
Monie
monie
Has thanked: 1 time
Post by monie »
LeighM wrote:
Wed Jun 28, 2023 10:47 am
Hi Monie,
I have installed the AVR/Arduino toolchain and checked the AVR toolchain location path in the global settings?
As was asked on an earlier post, have you created any successful Arduino projects, e.g. flashing LED?
There's something not quite correct with either the toolchain setup or settings in your Flowcode. According to your error logs the compiler isn't getting started.
It might help if you could post screen shots of your Flowcode settings dialogs. Toolchain location screen etc
monie
Has thanked: 1 time
Post by monie »
Hi LeighM
I have attached some screenshots .
Skærmbillede 2023-06-28 195808.jpg (100.37 KiB) Viewed 6522 times
Skærmbillede 2023-06-28 195645.jpg (43.74 KiB) Viewed 6522 times
Skærmbillede 2023-06-28 200704.jpg (53.02 KiB) Viewed 6522 times
Can you use some of these pictures?
Monie
monie
Has thanked: 1 time
Post by monie »
Has thanked: 302 times
Been thanked: 471 times
Those toolchain locations look wrong (apart from the ESP). These are pointing at the %PROGRAMDATA% location which is used internally for Flowcode's library updates.
Instead, these need to point to the location where you have installed the toolchains (there are separate installers for these on the Flowcode download page). Normally the toolchain itself 'tells' Flowcode where the toolchain has been installed to and these locations are set up automatically. By default, most of the toolchains will install themselves in the "C:\Program Files(x86)\..." location.
monie
Has thanked: 1 time
Post by monie »
Hi Steve-Matrix
Flowcode_Compiler_AVRv5 - HI have to re-install.
It helped Ardino Uno R3 which now runs well Flowcode v11
I am trying to use ILI9341 SPI Display on different devices.
So thank you very much for the help.
Monie
