Max7219 dot matrix 8x8
kaqkk007
Has thanked: 4 times
Been thanked: 4 times
Re: Max7219 dot matrix 8x8
Post by kaqkk007 »
Köszönöm
Has thanked: 177 times
Been thanked: 1027 times
Post by mnfisher »
Hopefully it works for you now. You'll need to set osccon for your required clock etc.
You might need to adjust the speed in properties too - if FOsc/4 doesn't work try FOsc/16 - I found the displays are quite sensitive to the quality of the wiring - use short good quality jumpers if breadboarding the project for example.
