Max7219 dot matrix 8x8
Monaga
Flowcode v10 Max7219 dot matrix 8x8
Post by Monaga »
I found this component (Max7219_V9.fcpx) in the forum, how can I use it in the recent version Flowcode10
It was created by Martin
Max7219_v9.fcpx
(8.89 KiB) Downloaded 1011 times
Has thanked: 177 times
Been thanked: 1027 times
Re: Max7219 dot matrix 8x8
Post by mnfisher »
It should work - there are quite a few examples dotted around the forums, Where did yoou find the above version?
Monaga
Post by Monaga »
Holas Martin, este componente lo encontré en este post
Anteriormente en la versión FC8, se instalaba el componente en la carpeta de COMPONENTES, y este aparecía en el listado, pero ahora en la versión de FC10 lo instalo en la carpeta y no lo puedo ver en el listado de componentes
¿Como puedo hacer, para que el macro aparezca en el listado?
Hello Martin, I found this component in this post “Martin Fisher great component Max7219_v2 a question Solved”
Previously in the FC8 version, the component was installed in the COMPONENTS folder, and it appeared in the list, but now in the FC10 version I install it in the folder and I can't see it in the components list
How can I do so that the macro appears in the list? Ready to use it
Thanks / Gracias
Monaga
Post by Monaga »
Dear Martin:
The component is working now, I misspelled the folder address
kaqkk007
Has thanked: 4 times
Been thanked: 4 times
Post by kaqkk007 »
Kipróbáltam , pic kontrollerrel hibára fut a fordítás
Post by mnfisher »
Which PIC did you try?
kaqkk007
Post by kaqkk007 »
16f628 16f876 és 18f252 et próbáltam
Post by mnfisher »
Can you post the code you tried? I only looked at one MCU - but the 18f252 should have plenty of RAM. What issue are you getting. Won't compile, or it doesn't work on hardware?
kaqkk007
Post by kaqkk007 »
Nem fordítja , a kódot ki töröltem . Ha tudnál egy példát küldeni annak örülnék .
Post by mnfisher »
Are you setting the pins in properties (including CS)
This should run through some demo routines...
I used the 18f252 but should work with others if they sufficient RAM - it uses 8 bytes for each of 16 displays (max allowed as far as I remember)
Note also that it doesn't do anything in simulation.
pic_max7219.fcfx
(9.14 KiB) Downloaded 513 times
