fatal error: CDC_Setup.h: No such file or directory
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Re: fatal error: CDC_Setup.h: No such file or directory
Post by SpeedPIC32 »
compiler:
Location = C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\PIC32compCDC.bat
Paramters = "$(chip)" "$(srcdir)" "$(target)" "$(family)"
Flowcode v9.0.0.23 Standard Version
Windows 10 Pro x64
Log:
Target folder: C:\Users\uwe\Documents\Daten\Matrix
Source name:   C:\Users\uwe\Documents\Daten\Matrix\USB.fcfx
Title:
Description:
Device:        PIC32.32MX.32MX470F512L
Generated by:  Flowcode v9.0.0.23
Date:          Tuesday, March 02, 2021 19:58:43
Users:         1
Registered to: SpeedPic32 (24146314)
Licence key: YHFEJD
   NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\PIC32compCDC.bat  "32MX470F512L" "C:\Users\uwe\Documents\Daten\Matrix\" "USB" "32MX"
Project USB
Device 32MX470F512L
Objects USB_32MX470F512L
C:\Users\uwe\Documents\Daten\Matrix>xc32-gcc -mprocessor=32MX470F512L -DMX_USBFS -IC:\Users\uwe\Documents\Daten\Matrix\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 -o "USB_32MX470F512L\USB.o" "USB.c" -DMX_USBFS
Der Befehl "xc32-gcc" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
Error(s) in build
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\PIC32compCDC.bat reported error code 0x1
Autoclose turned off
FINISHED
"Der Befehl "xc32-gcc" ist entweder falsch geschrieben oder
konnte nicht gefunden werden."
Means: 'The command "xc32-gcc" is either written wrong or could not be found.'
Has thanked: 645 times
Been thanked: 855 times
It looks like this might be a short path name problem. We are currently looking at ways to try and head this off in the next update for v9.
However for now this FAQ topic may help to get you up and running.
https://www.matrixtsl.com/faq/index.php ... artlang=en
It's designed for the AVR compiler but should also work for the PIC32 compiler. Instead of uninstalling Flowcode uninstall or rename the Flowcode PIC32 compiler toolchain.
SpeedPIC32
Did not work. Tried the quick way, with the registry change. Even added the path to the compiler in the environment path variable. The console finds the compiler. Flowcode doesn't. :roll:
Seems like I have to change the IDE or at least try to reinstall everything.
SpeedPIC32
Hi benj
I found the mistake.
I had the wrong batch file on the computer.
now I can compile without errors.
I will continue to test it.
Can't you set up a rubric in the forum with this help?
e.g. PIC32 USB and so on and put down all the help without the whole communication.
I mean, you can find a solution faster.
many thanks
another idea
you cannot generally write a batch file or a small EXE for such things; who makes these changes.
My son had to help me on the PC.
You just want to write your program in Flocode and not first fix errors in Flowcode yourself. Why don't you start a survey?
thank you again for your help
