fatal error: CDC_Setup.h: No such file or directory
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Post by SpeedPIC32 »
Hello Benj, LeighM and affected.
I am really angry :evil:
why does USB not work with the PIC32?
Since I've been using FC7 and FC8 and FC9 it doesn't work.
Pic choose,
USB choose
to adjust,
Initialize and compile without errors :D
It is exactly like that
I'm buying a new car with air conditioning.
In the summer I find out she doesn't work. :oops:
The dealership is trying to fix it, but open the window until we find the fault. :roll:
OK, I'll buy a newer model with air conditioning, it doesn't work either. :oops:
Last attempt, new car Does not work either. :evil: :evil: :evil:
do we always have to use a different chip for USB? :lol: :lol: :lol:
Please fix the build rate error immediately.
with kind regards to those affected
Has thanked: 607 times
Been thanked: 803 times
Re: fatal error: CDC_Setup.h: No such file or directory
Please can you post your project file and I'll investigate the problem for you.
Edit. I've managed to replicate the issue. Bear with me and I'll try and get it sorted for you.
SpeedPIC32
Hello benj,
a zip file attached
can you remove the USB interface from the PIC32mx1xx? They don't have any
I can also send a ZIP file for this.
Please also at some point the error with the wrong Baut setting
Thanks in advance
Matrix.zip
(14.42 KiB) Downloaded 625 times
Right here is what you currently need to do to solve the compilation problem.
1) You need to download and install the Harmony 1.11 library from here. This contains the USB drivers and missing files.
https://www.microchip.com/mymicrochip/f ... e=en597939
Make sure you install the harmony library in the default location C:\microchip\harmony\v1_11
2) In Flowcode click Build -> Compiler options
3) Select the PIC32 programmer you are using ICD3/PICkit3/PICkit4 from the list on the left and then click on the save button at the top right of the window.
4) Give the setting a new name e.g. PIC32 USBSerial
5) Select the new item you have created in the list on the left and change the compiler location to one of the following.
HID
$(compilerpic32)batch\PIC32compHID.bat
Serial
$(compilerpic32)batch\PIC32compCDC.bat
6) Change the compiler parameters to this.
"$(chip)" "$(srcdir)" "$(target)" "$(family)"
7) Tick the "Default compiler for platform" checkbox
8) Click the OK button
9) Next extract and copy the updated compiler scripts to the toolchain folder. C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch
PIC32_USB_Script.zip
(3.65 KiB) Downloaded 766 times
Fingers crossed the USB Serial and USB HID components should now compile correctly for you.
Sorry it's not anywhere near as plug and play as normal, this one seems to have slipped through the net several times. I'll add it to the list to try and make this a bit more seamless in future.
SpeedPIC32
hi Benj
can Harmoni version 3 be used?
you can't make a rubric in the forum where such relevant things are made public. e.g. changes since the last update for PIC AVR ESM32 and so on.
Then there is no need to search everywhere.
Many Thanks
We developed the component when Harmony 1.11 was the latest, Harmony 3 might work but the liklihood is it won't as things change over time.
Yes we try and apply most fixes via the update system. USB is currently an issue on PIC32 and AVR as you need external libraries and custom build scripts to make it work. We are working on ways to hopefully improve this so it's easier to make it work out of the box.
SpeedPIC32
followed your instructions, but it does not work.
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\PIC32compCDC.bat  32MX470F512L" "C:\Users\uwe\Documents\Daten\Matrix\" "USB" "32MX
Project
Device 32MX470F512L" "C:\Users\uwe\Documents\Daten\Matrix\" "USB" "32MX
Objects _32MX470F512L" "C:\Users\uwe\Documents\Daten\Matrix\" "USB" "32MX
C:\Users\uwe\Documents\Daten\Matrix>xc32-gcc -mprocessor=32MX470F512L" "C:\Users\uwe\Documents\Daten\Matrix\" "USB" "32MX  -I. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 -o "_32MX470F512L" "C:\Users\uwe\Documents\Daten\Matrix\" "USB" "32MX\.o" ".c"
Der Befehl "xc32-gcc" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
Error(s) in build
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\PIC32compCDC.bat reported error code 0x1
He seems to use the wrong path. But I don't understand why.
You seem to be missing the start and end quotes.
Here's how yours looks.
compared to mine
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\PIC32compCDC.bat "32MX470F512L" "C:\Users\Ben\Desktop\" "USB" "32MX"
Check your compiler options parameters has the quotes before $(chip) and after $(family).
SpeedPIC32
as you said, the quotes where missing. But the problem stays the same. He can't find "xc32-gcc".
Please can you post your latest compiler messages. It's all working as expected for me so it's strange it' not working for you.
C:\Program Files (x86)\Flowcode\Common\Compilers\pic32\batch\PIC32compCDC.bat  "32MX230F064B" "C:\Users\Ben\Desktop\" "PIC32_USB" "32MX"
Project PIC32_USB
Device 32MX230F064B
Objects PIC32_USB_32MX230F064B
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 -o "PIC32_USB_32MX230F064B\PIC32_USB.o" "PIC32_USB.c" -DMX_USBFS
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\usb\src\dynamic\usb_device.c" -o "PIC32_USB_32MX230F064B\usb_device.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\usb\src\dynamic\usb_device_cdc.c" -o "PIC32_USB_32MX230F064B\usb_device_cdc.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\usb\src\dynamic\usb_device_cdc_acm.c" -o "PIC32_USB_32MX230F064B\usb_device_cdc_acm.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\system\int\src\sys_int_pic32.c" -o "PIC32_USB_32MX230F064B\sys_int_pic32.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\system\devcon\src\sys_devcon.c" -o "PIC32_USB_32MX230F064B\sys_devcon.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC\CDCComp.c" -o "PIC32_USB_32MX230F064B\CDCComp.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC\CDC_FS_Desc.c" -o "PIC32_USB_32MX230F064B\CDC_Desc.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\driver\usb\usbfs\src\dynamic\drv_usbfs.c" -o "PIC32_USB_32MX230F064B\drv_usbxs.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\driver\usb\usbfs\src\dynamic\drv_usbfs_device.c" -o "PIC32_USB_32MX230F064B\drv_usbxs_device.o"
C:\Users\Ben\Desktop>xc32-gcc -mprocessor=32MX230F064B -DMX_USBFS -IC:\Users\Ben\Desktop\. -IC:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC32BIT\USB\CDC -IC:\microchip\harmony\v1_11 -IC:\microchip\harmony\v1_11\framework -w -c -ffunction-sections -O1 "C:\microchip\harmony\v1_11\framework\system\devcon\src\sys_devcon_pic32mx.c" -o "PIC32_USB_32MX230F064B\sys_devcon_pic32mxz.o"
C:\Users\Ben\Desktop\PIC32_USB_32MX230F064B>xc32-gcc -mprocessor=32MX230F064B -Wl,-T"C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic32\batch\..\bin\..\pic32mx\lib\proc\32MX230F064B\p32MX230F064B.ld",--defsym=__MPLAB_BUILD=1,--defsym=_min_heap_size=0,--gc-sections  "CDCComp.o" "CDC_Desc.o" "drv_usbxs.o" "drv_usbxs_device.o" "PIC32_USB.o" "sys_devcon.o" "sys_devcon_pic32mxz.o" "sys_int_pic32.o" "usb_device.o" "usb_device_cdc.o" "usb_device_cdc_acm.o" -o "..\PIC32_USB.elf"
C:\Users\Ben\Desktop\PIC32_USB_32MX230F064B>xc32-bin2hex "..\PIC32_USB.elf"
C:\Users\Ben\Desktop\PIC32_USB_32MX230F064B>xc32-objdump -t -d  -h "..\PIC32_USB.elf"  1>"PIC32_USB.lst"
C:\Users\Ben\Desktop\PIC32_USB_32MX230F064B>xc32-size -B "..\PIC32_USB.elf"
   text	 rodata	   data	    bss	    dec	    hex	filename
  16828	    392	     80	    852	  18152	   46e8	..\PIC32_USB.elf
Compilation successful
