App Developer - Modbus Master
Has thanked: 616 times
Been thanked: 814 times
Re: App Developer - Modbus Master
Hi Steve,
Yes the modbus devce is replying there :D
Can you post your program and I'll have a look for you what the problem might be.
steve001
Has thanked: 81 times
Been thanked: 30 times
Post by steve001 »
Hi Ben,
chart attached this is a different instrument i borrowed from work, whilst i try and get my around how the scada is working and how to display things. As the RI-F550 has some hefty registers.
40029 - is a temperature register 0 - 150 degrees C
Bit confused - i watched your modbus tutorials on you tube, and when you showed the console the replys where blue with - ok at the side in green .
or is that just for the TCP version of the component ?
Modbus Test 2.fcsx
(11.05 KiB) Downloaded 349 times
