As a test - try printing the string to the display.
ie - is it received incorrectly / converted incorrectly / sent as a float incorrectly...
Try and home in on the error.
Best tactic to decode JSON data..
- Has thanked: 156 times
- Been thanked: 904 times
Re: Best tactic to decode JSON data..
As a test I already did both.
The string is shown like it should, the float doesn't have decimals.
My guess is that the ILI9488 treats the float as an integer..?
- Has thanked: 429 times
- Been thanked: 647 times
It's a silly question/thought...
If you are using the ILI9488 PrintNumber to display the value then it will, indeed, get converted to am integer. PrintNumber takes an Int (so just 16 bits too) - and no digits after the point!
Oh my, you are right again.
My life is hell
After all this time still make these mistakes, I was pretty sure that it took a Float too.
Now I really have a problem because I want to show the the number with only one decimal and need to calculate with this number.
I will work it out, but it should be great to have a component that shows all kinds of numbers, I know this is a lot of work...
Will figure it out.
Thank you again Martin!
My life is hell
Will figure it out.
We got there in the end....
Easily done - see my post this evening about trying to fit 16 bits of data into a byte
Sometimes it just needs a different pair of eyes.
You could have a macro PrintFloat - that takes a float x (and possibly number of digits after dp) and a position - convert x to a string using FloatToString$ - then print the string....
You can limit the number of decimal places
viewtopic.php?p=7248&hilit=number+of+de ... aces#p7248
You could use that for calculations, and then print.
