compiling to hex
Has thanked: 163 times
Been thanked: 960 times
Re: compiling to hex
Post by mnfisher »
That's odd. Would expect to cause issue with any xc8 compilation. Wonder how the 18f452 differs from other targets?
bazkhf
Has thanked: 5 times
Been thanked: 2 times
Post by bazkhf »
Proposal for a Permanent Solution:
I would like to suggest adding an automatic check feature within Flowcode, where the program automatically removes spaces from file names or replaces them with underscores before the compilation process begins. If this is not feasible, a warning could be added to notify the user that the file name must be free of spaces. This would help reduce issues related to file names with spaces and make the compilation process smoother.
Has thanked: 292 times
Been thanked: 458 times
Thanks for the suggestion, but automatically renaming files could cause more issues than it solves. This issue related to the XC8 compiler and affects just the 18F452 chip AFAIK, so the vast majority of users will never notice the issue.
And if it is even an issue, then it can be raised on this forum and addressed as it has been within this topic.
