STM32F QUESTIONS
Has thanked: 103 times
Been thanked: 302 times
Re: STM32F QUESTIONS
Btw. You might need to do a board power cycle for changes in this domain to take effect
max.tisc
Been thanked: 12 times
Post by max.tisc »
great LeighM
turned it off and on again and the LED started flashing and I get the date and time, I tried to change the date and time and everything works correctly
thanks
Screenshot 2025-01-12 213101.png (225.96 KiB) Viewed 7247 times
max.tisc
Flowcode v9 Re: STM32F QUESTIONS
Post by max.tisc »
Hi LeighM
unfortunately I found another problem with the internal RTC whether it is configured as LSE or as LSI, I noticed that if the card is turned off for a while (a few hours) the RTC does not start and blocks the program, I do the initialization of the RTC first and only after several turns on and off it restarts, but if I turn it off for a few seconds when I turn it back on it resumes normally and the time has gone forward despite there being no external battery or large capacitors on the power line (probably the few uF of filter are enough to keep it active for a few seconds)
thanks
Screenshot 2025-01-27 181406.png (167.45 KiB) Viewed 6806 times
max.tisc
Post by max.tisc »
other info that maybe can help you
1) I wanted to write a few minutes and not hours
2) I lowered the Hclk to 25 Mhz (before it was 80Mhz) and the failure to restart has become more sporadic
3) I eliminated LSE as the main clock and set HSI RC and working at 16Mhz the problem occurs very very rarely
4) just now I realized that probably when the program seems blocked in reality it is greatly slowed down in the video that I managed to load you can see the LED flashing very fast while when it seems blocked the LED flashes very slowly
thanks
OK.zip
(818.68 KiB) Downloaded 251 times
NOT OK.mp4.zip
(2.4 MiB) Downloaded 278 times
It could be that startup times for the LSE oscillator are causing issues.
For the RTC to work properly you need a constant battery supply to VB pin.
The Battery backup domain section of the Reference manual RM0383 provides some useful information.
This can be downloaded from the st.com website.
max.tisc
Post by max.tisc »
ok LeighM thanks
now I added a 3V button battery between the Vbat and negative pins and this happens:
setting the main oscillator on HSE and the RTC oscillator on LSE (crystal exsternal screenshoot 2) 10 times out of 10 the program does not start
if I leave the main oscillator on HSE and the RTC oscillator on LSI ( LSI RC screenshoot 1) , the program always restarts even after several minutes but minutes and seconds in the time in which the main power was disconnected the time did not go forward, but restarts from the moment it was disconnected
Could you put the RTC initialisation code on a button or serial command?
That is, just do it once to setup the RTC, not on every reset or display.
max.tisc
Post by max.tisc »
ok I'll try and let you know (I hope I understood what you're asking)
max.tisc
Post by max.tisc »
Hi, I've done a lot of tests and this configuration has never given me any problems with the program crashing.
I've put the code into the CAL file (STARM_CAL_RTC.c)
this goes into directory...
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM\
This will avoid the need for the extra C icon code.
Note that if you swap between LSI and LSE you need to cycle all power
STARM_CAL_RTC.c
(8.16 KiB) Downloaded 244 times
