MAX7219 32x32 LED Display
Has thanked: 177 times
Been thanked: 1027 times
Re: MAX7219 32x32 LED Display
Post by mnfisher »
Converted to a LUT anyway - most MCUs don't have the RAM of the esp32 so usually better in flash?
max7219x16_component_lut.fcfx
(33.94 KiB) Downloaded 727 times
Display4x4Max7219.fcpx
(4.75 KiB) Downloaded 736 times
kaqkk007
Has thanked: 4 times
Been thanked: 4 times
Post by kaqkk007 »
megnézzük ...
kaqkk007
Post by kaqkk007 »
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Errors when generating C source code:
Flowcode1.c : 558 : error : Syntax error
Autoclose turned off
Ezt írja fordítás helyett
Post by mnfisher »
Try:
There seemed to be a 'double comma' in the data... I just re-pasted the data however - and all seems well?
Memory Summary:
Program space used 8E6h ( 2278) of 8000h bytes ( 7.0%)
Data space used 15Fh ( 351) of 600h bytes ( 22.9%)
Configuration bits used 7h ( 7) of 7h words (100.0%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
ID Location space used 0h ( 0) of 8h bytes ( 0.0%)
Data stack space used 0h ( 0) of 400h bytes ( 0.0%)
For test_led
(33.9 KiB) Downloaded 739 times
(4.76 KiB) Downloaded 724 times
kaqkk007
Post by kaqkk007 »
a változatosság kedvéért most : NOT FOR COMMERCIAL USE
Flowcode1.c : 562 : error : Syntax error
kaqkk007
Post by kaqkk007 »
Maga a komponens befordul , de ha a főprogramba beteszeszem az init-et már jön a szintaxis hiba 558
Post by mnfisher »
It moved! Can you post the file you are trying to compile?
And what version of FC are you using?
Did you reload the chart after copying the new component?
kaqkk007
Post by kaqkk007 »
I'm working with version 10, and there's no file because, as I mentioned, it throws a syntax error as soon as I import the init file—it doesn't matter which macro I import.
Flowcode1.fcfx
(8.64 KiB) Downloaded 707 times
Flowcode1.fcfx
(8.64 KiB) Downloaded 708 times
Post by mnfisher »
Yes - bombs v10 :-)
I tried re-exporting from v10 (it didn't like the .x |= .value syntax of v11.
However - still crashing v10. Will play more after lunch!
kaqkk007
Post by kaqkk007 »
I hope the situation isn't too serious; I'm waiting to hear how it turns out.
