Flowkit 2 and Ghost EB006V)
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: Flowkit 2 and Ghost EB006V)
Post by p.erasmus »
Thanks for the comment
However I am aware of this issue and in my very first post in this tread I mentioned that I am using external OSC with 16Mhz
and in the screen print you will notice I unabled the Internal OSC setting due to running External
quote from the first post
just a note I am using 16Mhz no PLL external Chrystal so the issue with internal OSC and Ghost it is not
p.erasmus
Post by p.erasmus »
Hi Ben,
This issue is solved with 25K22 and EB006 it seems the PC USB posrt does not have enough current drive :D I changed to external Power supply and the Ghost is working,I do not know Flowkit but for now I am ok with debugging .The confusion part is the code run well with the USB connected it seems it is only when I switch Ghost that the port cannot handle the little 1 or 2 mA more :D :D I did not think about such problem
Has thanked: 103 times
Been thanked: 302 times
Well spotted! Thanks for the update :D
