ST7789 display
Has thanked: 646 times
Been thanked: 855 times
Re: ST7789 display
I've now added support for more fonts and a lot of the fonts should now be working. I haven't done everything so please let me know if you are using a font that is currently unsupported.
Also typing this in should now work in the latest component, "ºC" e.g. alt 167 or alt 248.
jollybv
Has thanked: 42 times
Been thanked: 15 times
Re: ST7789 display
Post by jollybv »
That's great thanks i will try them out a bit later have the screen working with the default font but will now go back and try the Callibri 11 font i was using.
jollybv
Re: ST7789 display
Post by jollybv »
I did a full update now the program will not compile I have not changed anything.
compiler error.txt
(68.71 KiB) Downloaded 841 times
Re: ST7789 display
Sorry that was an unrelated error to do with the watchdog timer auto clear feature being enabled, should be solved now.
jollybv
Re: ST7789 display
Post by jollybv »
Its still not compiling if you like i can PM you my code
compiler error1.txt
(67.94 KiB) Downloaded 554 times
Re: ST7789 display
Sorry about this, I have tried again and can't make the auto watchdog thing work nicely so for now I'm taking it back out and I might try another way.
Should be out for you now.
jollybv
Re: ST7789 display
Post by jollybv »
Thanks again it is working now have not tested with other fonts but will test and let you know but have tested with "Alt 0176" and that working fine
jollybv
Re: ST7789 display
Post by jollybv »
I did a library updated now the Degree symbol has changed, I have tried using both ASCII 167 and 248 but they both are displaying ASCII 240, not sure if a gremlin jumped in the update
Re: ST7789 display
Hmm ok I'll investigate for you, Which font are you using?
jollybv
Re: ST7789 display
Post by jollybv »
Hi Ben the default font
