I try install Mosquitto TLS but what is the good place in the MQTT Component to add the Server Certificate CA.CRT file, Client Certificate Client.CRT file and the Client Key Client.KEY file ?
Thank you.
Embedded device controlled from the Web without ESP
- Nico595
- Has thanked: 20 times
- Been thanked: 5 times
- Has thanked: 311 times
- Been thanked: 479 times
Re: Embedded device controlled from the Web without ESP
We currently do not support client-side certificates.
Martin (@mnfisher) has had success implementing client-side certification on the ESP32 here:
viewtopic.php?p=18770#p18770
Thank Steve,
Could be a good idea to add this function in the next MQTT component update
I will look the mqtt.fcfx by Martin and I see if I can use this code in my project.
Thank you.
Thank you.
