Hi Bob.
That's great!
I'm glad it's working perfect, thank you for your update.
We need Ben to state his opinion of should it be added or not.
If he says yes, then I will add it to all switch arrays.
Switch array
- Has thanked: 748 times
- Been thanked: 808 times
siliconchip
- Has thanked: 21 times
- Been thanked: 1 time
Re: Switch array
Hi martin
Whats the best way to get bens attention on this and the recent rotary switch debate?
Cheers bob
Cheers bob
Re: Switch array
Ben does read the forums
You need to bare in mind that he is pulled in different directions where he works and it's currently the holiday season for other staff, he could be needed to cover for.
At least currently you have a working version.
If you want to replace any arrays in other projects with the reverse type, just add the reverse type to the 2d panel, right-click on the original array and select Replace
Select the Switch Array Reversed from the Component Replacement pop up window, then OK.
That will save time when compared with manually changing each switch array function.
