thingsboard, hivemq etc. using ESP32 or ESP8266 MQTT. I failed to send data. What am I doing wrong?
Has thanked: 177 times
Been thanked: 1026 times
Re: thingsboard, hivemq etc. using ESP32 or ESP8266 MQTT. I failed to send data. What am I doing wrong?
Post by mnfisher »
Actually you don't need to do this.
True - however, the component used here should allow the secure connection on port 8883.
The config passed to the esp_mqtt_connect needs some slight changes (the verification key needs to be set, and the broker address needs to change to connect to the secure port) - I'm hoping this will prove to be straightforward (famous last words?))
Post by mnfisher »
Here it connects securely.
The hard part was finding the correct certificate (in the end I downloaded from DigiCert)
The code also needs to get the current time - which it does using the SNTP component.
As before - needs channel, password, username and SSID details..
mqtt.fcfx
(29.02 KiB) Downloaded 170 times
